Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
 Post subject: raw preset loud and bass
PostPosted: Wed Mar 05, 2014 9:39 pm
Goal: bass and loudness, web only , FM is comming up in the next day's
[s]7 band[/s] 9 band
Steep filters in the first 2 bands for extra basscontrol in the MB
High knee and ratio settings als wel.
Slow releases
Then lossen up things for cleaner mids and highs> faster releases
Hope you'll like it!
File comment: Warp factor nine :)
warp-factor-9.sts [49.69 KiB]
Downloaded 824 times
Test stream OGG
Test stream FLAC
Last edited by Marthijn de Rooy on Mon Jul 21, 2014 3:03 pm, edited 1 time in total.
PostPosted: Wed Mar 12, 2014 2:05 am
Serious updates!
Warp factor 9 by TinoV V0.2.sts [49.74 KiB]
Downloaded 576 times
Test stream OGG
Test stream FLAC
PostPosted: Wed Mar 12, 2014 4:12 am
More loudness control
Warp factor 9 by TinoV V0.3.sts [49.72 KiB]
Downloaded 574 times
Test stream OGG
Test stream FLAC
PostPosted: Thu Mar 27, 2014 6:07 pm
Multiband improvement
AGC improvement
Adjustments in clipping
Adjustments in stereo imaging
Warp factor 9 by TinoV V0.4.sts [49.81 KiB]
Downloaded 649 times
Test stream OGG
Test stream FLAC
PostPosted: Thu May 01, 2014 1:33 am
Now there is MPX
Preset made using :
Core I 5 PC
Realtek ALC 982
Elenos ETG 100 transmitter
Soon stokkemask proof ( now overshoots up to 82 KHZ when elenos shows 75 KH deviation, phase problems realtek)
REAL FM.sts [48.59 KiB]
Downloaded 596 times
Test stream OGG
Test stream FLAC
PostPosted: Fri May 30, 2014 9:10 pm
Update: V0.6
Removed MPX, that comes later
AGC :
Slower and less mid and highs
Multiband :
Better ( lesser) limiting in MB after compression for less distortion especially when driven hard
Lower Q factors in band filter ( still relative high Q for the 2 lowest bands for more precise control in the MBC )
Lower "knee" values so the compressor doesn't act like some kind of limiter :), that leaves some more dynamics in the signal.
Tweaking of the Advanced clipper for less distortion because of more dynamic signal from the MBC.
I run a test stream , most of the tracks are lossless wav from good sources ( no Mp3 2 wav conversion or someting )
The stream has a EDM format in the weekend
Check it out here :) 320 Kbps )
http://realsound.dlinkddns.com:10000/listen.pls
Warp factor 9 V0.6.sts [49 KiB]
Downloaded 592 times
Test stream OGG
Test stream FLAC
Last edited by Marthijn de Rooy on Mon Jul 21, 2014 2:58 pm, edited 1 time in total.
PostPosted: Mon Jul 21, 2014 2:57 pm
V0.7 is here!
Tweaking , Tweaking , Tweaking
MPX is back
Warp factor 9 V0.7.sts [56.75 KiB]
Downloaded 547 times
Test stream OGG
Test stream FLAC
PostPosted: Sat Aug 09, 2014 3:13 am
First of all
Thumbs up for the mono bass in V 7.5, THIS RULES!
Ok now that has been said ......the following.....
Sorry for posting my audio config settings , from now on FM and WEB settings without my personal audio settings :)
So here it is ..
V0.75
Leave some feedback if you like it, if not..............do the same :)
Next work , cleaning up the highs and the low midbass just above 135 HZ
Warpfactor 9 V 0.75 FM.sts [53.33 KiB]
Downloaded 529 times
Warpfactor 9 V 0.75 WEB.sts [50.6 KiB]
Downloaded 510 times
Test stream OGG
Test stream FLAC
PostPosted: Fri Aug 15, 2014 5:17 pm
V0.85 is here
Better sound in the lower midrange and better highs like in better defined high-hats
Less deep bass for more punch , adjustments in bass amp and MB ( cross and level )
Tweaked the stereo imaging and multiband because of to much mid
Overal loudness has improved
Less harsh sounding because of less steeper Knee settings( higher value's )
Now focussing more on the intertia stuff for more SSSSSS control ,i have to figureout how the de-esser and the intertia settings work together
FM version will come soon, i have to tweak some settings in the advanced clipper for that
Game on :)
Warpfactor 9 V 0.85 WEB.sts [50.44 KiB]
Downloaded 549 times
Test stream OGG
Test stream FLAC
PostPosted: Thu Aug 21, 2014 2:56 am
FM is here
Tweaked stereo and density and high prio in the advanced clipper
Things to do :
Fine tunning :)
Warpfactor 9 V 0.85 FM.sts [54.2 KiB]
Downloaded 565 times
Test stream OGG
Test stream FLAC
