 Post subject: Equalize pre or post ?
PostPosted: Mon Apr 27, 2009 2:58 pm
Hi Hanz
Please prompt. For FM Broadcast it is better to put equalizer before multicompresor or after?
PostPosted: Mon Apr 27, 2009 4:26 pm
That doesn't really matter... Using it AFTER the multiband compressor is similar to using it before, and changing the "soft limit" settings accordingly. This is only an "ease of use" issue. Say you have configured the bass, and you want more bass without increasing the maximum bass volume, then you use it before the multiband compressor, otherwise you use it afterwards.
Just make sure that the final limiter doesn't show too much dark red. If it does it may cause (some) distortion.
