PostPosted: Sat Jan 25, 2014 7:58 am
Being a long-time user of both the free MediaPortal HTPC front-end and Stereo Tool, I'd love to be able to use both at the same time. The problem is that Stereo Tool crashes when changing tracks a few times (click F7 or F8) in a row in MediaPortal:
Log Name:      Application
Source:        Application Error
Date:          25.1.14 08:31:04
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      HTPC
Description:
Faulting application name: MediaPortal.exe, version: 1.6.0.0, time stamp: 0x52b77bd2
Faulting module name: vst_stereo_tool.dll, version: 0.0.0.0, time stamp: 0x52b8366b
Exception code: 0xc0000005
Fault offset: 0x004eee29
Faulting process ID: 0xb90
Faulting application start time: 0x01cf1996f5a06477
Faulting application path: C:\Program Files (x86)\Team MediaPortal\MediaPortal\MediaPortal.exe
Faulting module path: C:\Program Files (x86)\Team MediaPortal\MediaPortal\musicplayer\plugins\dsp\vst_stereo_tool.dll
Report ID: 437fd10e-858a-11e3-8276-e840f2d290a6
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2014-01-25T06:31:04.000000000Z" />
    <EventRecordID>2753</EventRecordID>
    <Channel>Application</Channel>
    <Computer>HTPC</Computer>
    <Security />
  </System>
  <EventData>
    <Data>MediaPortal.exe</Data>
    <Data>1.6.0.0</Data>
    <Data>52b77bd2</Data>
    <Data>vst_stereo_tool.dll</Data>
    <Data>0.0.0.0</Data>
    <Data>52b8366b</Data>
    <Data>c0000005</Data>
    <Data>004eee29</Data>
    <Data>b90</Data>
    <Data>01cf1996f5a06477</Data>
    <Data>C:\Program Files (x86)\Team MediaPortal\MediaPortal\MediaPortal.exe</Data>
    <Data>C:\Program Files (x86)\Team MediaPortal\MediaPortal\musicplayer\plugins\dsp\vst_stereo_tool.dll</Data>
    <Data>437fd10e-858a-11e3-8276-e840f2d290a6</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
I have tried a few versions of the VST DLL but the result is the same. The error report is from using the current 7.40 release.
Thanks in advance for your help.
BR,
-P.
P.S. Using the Winamp DSP version is currently not a solution for me, because of stuttering sound during track crossfade with BASS music player engine and WASAPI playback is currently broken on my hardware.
PostPosted: Sat Jan 25, 2014 4:57 pm
This is an odd one. Because I think the VST plugin doesn't even know when a new track starts - so how can it respond to that?
Have you by any chance ever tried another VST module, preferably one that is similar in CPU usage?
PostPosted: Sat Jan 25, 2014 5:42 pm
No, unfortunately I don't have much experience with other VST modules. Another MediaPortal user mentioned in one of his posts using Classic EQ and I just tried playing around with it for a few minutes & a couple of dozen track changes. I was unable to make it crash.
If you know another VST module that compares better with Stereo Tool's CPU usage, I'd be happy to give it a try. Here are my system specs, in case they play a role:
  • Windows Version: Windows 8.1 Pro x64
    CPU: Intel® Core™ i5-3570K
    Mainboard: Intel® Desktop Board DH77DF
    RAM: 8 GB
    HDD: 30 GB OCZ Vertex 2.5" SSD
Even with Declipper activated, I don't see ST pushing the CPU very hard.
PostPosted: Tue Jan 28, 2014 6:37 pm
I did some more testing with previous versions of ST available on the download page. Something must have changed between versions 6.32 and 7.23 that causes this issue, because version 6.32 does not crash and version 7.23 does.
Hope this helps.
-P.
