 Post subject: Gating in SB
PostPosted: Mon Jan 06, 2014 11:14 pm
Hello Hans,
I have the issue, that the Singleband doesn´t gate (freeze), regardless to the gating threshold.
I am still using the 7.31, not tested in 7.40, could you check this?
Thank you,
Regards,
Robert Sack
 Post subject: Re: Gating in SB
PostPosted: Tue Jan 07, 2014 1:34 am
Hello Robert,
It does not freeze but it does slow down - and that works (I've just checked).
Btw - since you asked a lot of things about the AGC: Please check version 7.40! Among others, the AGC is improved a lot. None of the things that you asked - but it definitely works better than before.
