PostPosted: Fri Nov 08, 2013 2:13 pm
Hello,
I have a question:
I can´t see any meterings in the Web access screen of Stereo tool.
Is it normal or is it an error of my browser (there is no error/block message)?
I have tried it with Internet Explorer and Mozilla Firefox.
Regards,
Robert Sack
PostPosted: Fri Nov 08, 2013 4:34 pm
This is normal. I want to make *something* in the future, but as you can probably imagine, sending over (big) images isn't really an option, and continuous data transfer might not be good either for people on mobile connections who pay per amount of data transmitted.
I think I'll need to write a standalone application so you can control ST from another pc (mac, linux) - browser/webinterface support will stay but it's not the easiest way of doing things. Definitely not suitable to setup a preset (but if you're driving around in a car with your mobile phone and want to switch SSB or Stokkemask on and off to test multipath distortion, or change an RDS text, it's usable).
PostPosted: Sun Nov 10, 2013 4:12 pm
VNC is the best to use everything of Stereo Tool from another computer. Metering is maybe slow, but at least you get a good indication.
PostPosted: Mon Nov 11, 2013 11:12 am
Hello,
Thank you for your fast reply. Yes of course, it´s a good way to use remote tools. I was only unsure if occaisionally my browser blocks something, therefore was this question.
Regards,
Robert Sack
