 Post subject: Translate to Spanish
PostPosted: Tue Oct 29, 2013 7:10 pm
To inaugurate the subforum, I share a file with the translation into Spanish (Latino) to ST. ;)
Spanish I tried to put in everything, but I left some texts in English or Span-Inglés, as they have in Spanish a translation understandable. :(
This is a first version, anything you see that does not go, let me know and we will adjust. :lol:
Note: I upload the file in. Zip, since it can not climb. Stl. Unzip and place next to. Exe or. Dll ST
Spanish (Español).zip [10.33 KiB]
Downloaded 1457 times
by GAP
"Less is More" (Bob Katz)
 Post subject: Re: Translate to Spanish
PostPosted: Wed Oct 30, 2013 2:33 pm
Cool! Thanks! I'll check why you cannot upload .stl files (I guess I need to add the extension somewhere).
PostPosted: Wed Oct 30, 2013 4:44 pm
Surely :roll:
by GAP
PostPosted: Wed Oct 30, 2013 5:07 pm
Posting .stl files is allowed now!
PostPosted: Tue Jan 14, 2014 10:52 am
Español: Hola me podrian explicar como se instala en el steretool el lenguaje .stl que he descargado?
English: (google translate) Hello I could explain how the language is installed on the steretool. Stl that I downloaded?
PostPosted: Tue Jan 14, 2014 1:52 pm
Hola barton1025, el archivo de lenguaje descargado lo debes copiar en el mismo path que tenes el ST, y luego podes elegir el lenguaje desde el ST en Configuration -> Language. Acá está explicado http://help.stereotool.com/7.40/configuration.shtml
Hello barton1025, the language file downloaded you have to copy the same path that got the ST, and then can choose the language from the ST in Configuration -> Language. Here is explained http://help.stereotool.com/7.40/configuration.shtml
by GAP
