PostPosted: Tue Oct 22, 2013 4:36 pm
Not sure this is a limitation in my computer or in ST, but with a mouse, I can set the FM Output Buffer Size anywhere from .001 up (I usually run it at .010). On the Web Interface, it jumps from .001 to .020. If the same resolution that's possible with a mouse could be extended to the web interface, that would come in handy.
PostPosted: Tue Oct 22, 2013 6:37 pm
How can I load/save presets using the Web Interface? I'm assuming that seeing the gain reduction and other displays is not an option at this time?
