 Post subject: CTE TX250 FM Transmitter
PostPosted: Thu Sep 26, 2013 12:00 am
Does anyone out there own the manual to the CTE TX250 FM Transmitter. Not the PLUS .
Im looking for the dipswitch diagram to change the frequency.
Cheers Ian
PostPosted: Thu Sep 26, 2013 6:13 am
Hi ianoogly,
I might have what you need but will need to search through some documents to check...
Edit: I sent you a pm. Hope it helps.
PostPosted: Wed Oct 30, 2013 8:04 pm
Hi ianoogly,
Could you send it to me also please? I have been searching around the web for weeks and can not find it!
Thanks you :)
PostPosted: Wed Oct 30, 2013 11:43 pm
Do you have dropbox on your PC. If so please send me your email so I can invite you to a folder which the manual is in.
regards Ian
PostPosted: Thu Oct 31, 2013 12:01 pm
regards Ian
Hey thanks heres my email for dropbox.. irishgreen2006@hotmail.com
thank you
PostPosted: Tue Apr 28, 2020 4:37 pm
I realize this is an extremely old topic, but if someone still has the manual for the CTE TX250, I'd very much like to acquire a copy.
PostPosted: Sat Jun 06, 2020 11:45 pm
Hi everybody!
I also need the manual for the CTE TX250, I'd very much like to acquire a copy
my email [removed by mod, send a PM please]
Thanx in advance,
jim
PostPosted: Tue Jul 07, 2020 3:41 pm
EDIT: I misread. This is for the PLUS version. What version is it that you need? I see S and W and stuff.
I gave it a cursory search and came across a Russian language version that works with Google's website translation tool.
ORIGINAL: https://www.manualsdir.ru/manuals/25902 ... -plus.html
ENGLISH TRANSLATED: http://translate.google.com/translate?h ... -plus.html
EDIT: Here's a place that has the TX250S https://www.scribd.com/document/323624416/TX250S-Manual
Hopefully this will contain enough clues to do what you're looking for.
