 Post subject: CHR
PostPosted: Thu Sep 12, 2013 3:46 pm
My new preset, using natural dynamics and the declipper. Leveling, bass and a "full sound".
Hope you like it!
CHR.sts [46.28 KiB]
Downloaded 600 times
 Post subject: Re: CHR
PostPosted: Sat Sep 14, 2013 7:32 pm
Preset is not bad at all :) With a few adjustments to fit in my environment it's a good CHR preset.
PostPosted: Mon Sep 16, 2013 9:03 am
Thank you for your reply! Can you share your adjustments? :-)
PostPosted: Mon Sep 16, 2013 11:56 am
New version:
+Changed AGC settings (thanks Hans for the tip) using Bojcha - J-Type settings. :-)
CHR 0.3.sts [50.11 KiB]
Downloaded 456 times
PostPosted: Mon Sep 16, 2013 7:46 pm
CHR 0.3 has too much hights and it doesn't sound like the typical CHR station.
You may hear the preset on air.
PostPosted: Mon Sep 16, 2013 10:54 pm
I agree on the highs, I guess you mean with "does not sound like a typical CHR station" that it is too clean?
Thanks for the feedback, I'm already working on 0.5 so I'm going to adjust that a bit. New version is coming soon! :)
PostPosted: Tue Sep 17, 2013 9:15 pm
New version:
+Back to the old AGC (Tweaked it a bit)
-Highs
CHR 0.6.sts [48.17 KiB]
Downloaded 495 times
PostPosted: Thu Sep 19, 2013 1:00 pm
Not bad, but I liked the first one better for some reason - it has that specific heavily-compressed CHR sound that most CHR and AC stations sound like today (love that "arena"-like effect that this preset has on most music instruments).
The new one is less aggressive and sounds cleaner, not the typical CHR sound that most stations use.
Regards!
PostPosted: Thu Sep 19, 2013 1:22 pm
Yeah.. clean is very bad! xD
PostPosted: Sat Oct 05, 2013 2:19 pm
CHR 0.3 sounds really good BECAUSE it's not too compressed. It would sound better with more bass and less treble, though. But I can't figure out how to adjust the setting. Any suggestions?
Thanks!
