PostPosted: Mon Sep 09, 2013 9:28 am
please help my problem! Radioboss v. 4.8.3 + stereo tul v.7.03 .... sometimes there are short-term loss of music (1-2 seconds). Pereodichnost a failure I had not noticed. What do I do?
PostPosted: Mon Sep 09, 2013 9:31 am
+ sound Card juli@
PostPosted: Mon Sep 09, 2013 9:54 am
Newest version of Stereo Tool is 7.30, you can try to update it. Probably buffers too low, is the coloured bar visible at NO (Normal Output), or in case you use FM Output? Maybe you can raise this buffers up at sound card menu.
PostPosted: Mon Sep 09, 2013 10:33 am
I do not use fm. Sound menu is available in radioboss? there was a buffer of 500 ms, 1000 ms I installed. - the situation has not changed. I will try to upgrade to stereo tool v.7.3
Can you recommend something else?
PostPosted: Tue Sep 10, 2013 10:12 am
I don't know Radioboss, I meant only the settings in ST. Do you use the standalone version on a separate computer? In case you use standalone ST the best results you get when you use a separate computer.
PostPosted: Wed Sep 11, 2013 3:03 am
Are you using FM output via Sound cards -> FM in Stereo Tool, or are you streaming and do you have gaps in the stream?
PostPosted: Thu Sep 12, 2013 3:50 pm
I do not use streaming audio, I have my own mp3 playlist.Change from 7.03 to 7.3 to no avail ... there is still a short-term loss of sound (1-2 seconds). I use a parallel with another radioboss playback of streaming audio on the same computer ... it could be a problem?
PostPosted: Thu Sep 12, 2013 11:57 pm
So not streaming but what do you use? FM? Or just listening directly? And how often does it happen?
PostPosted: Fri Sep 13, 2013 7:10 am
which the sequences (patterns) in failure there is no sound. I printed out the sound on the audio splitter directly to the sound card. Our radio is internal to the mall (not FM). I'm inclined to blame that pologat second radioboss that runs on the computer and plays the streaming audio.
PS I increased the buffer to the sound card of up to 2500 ms .... yes it can
PostPosted: Sat Sep 14, 2013 10:31 am
after changing the buffer sound card up to 2500 ms frequent loss of sound (up to 30 times a day). Changed the buffer to 400 ms, the day never sound disappeared
