 Post subject: license in vst
PostPosted: Thu Aug 29, 2013 5:58 pm
there seems to be a problem with pasting the license into the vst version. in winamp it works ok. i am using it in Ableton
 Post subject: Re: license in vst
PostPosted: Fri Aug 30, 2013 1:29 pm
Does that mean that you cannot paste it?
You can type it in manually... I know it's annoying. Some VST hosts apparently don't send certain key combinations to the VST plugin.
PostPosted: Sat Aug 31, 2013 10:18 am
no, i can't even type it. do you think it's a problem with ableton?
PostPosted: Sat Sep 07, 2013 12:27 am
It sounds like an issue with Ableton. I personally use StereoTool in both Adobe Audition and Goldwave; neither program has ever had an issue letting me paste (using Ctrl-V) or type in the license key.
