PostPosted: Wed Jul 09, 2008 2:22 am
Like you did included on having a function that uses equalizer before or after multiband, there should be function for that for stereo image and center bass as well. For centering bass, there should be a function called before or after other stereo image effect. It seems centering bass works before using fake stereo delay which make this bass function less useful. For the stereo image in general, a function should be before or after multiband. :)
PostPosted: Thu Jul 10, 2008 2:12 am
Performing Stereo after Multiband isn't a very good idea because the volume peaks change when the stereo image is changed. So it should always be done before compression.
I'll look into the center bass remark. Currently "Center bass" is a part of the increase phase processing. I could split the two, then I can just put center bass at the end without moving anything else.
I'm currently setting up my new pc so I can't really look into it right now, but when things are working properly again I'll look into it.
