 Post subject: start with windows
PostPosted: Mon Jul 29, 2013 3:57 pm
hi , what can i do SO the S.T. starts with windows automaticaly after a power break down or just a restart ?
thanks
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
 Post subject: Re: start with windows
PostPosted: Mon Jul 29, 2013 4:09 pm
Standalone?
Just copy shortcut into startup folder. ( START > Programs > Startup )
PostPosted: Mon Jul 29, 2013 4:18 pm
Standalone?
thanks Bojcha ! do you know what should i do for my PC starts automatically after a power break down ?
windows xp !
thanks again
Vanilla Radio
PostPosted: Mon Jul 29, 2013 4:21 pm
Make a shortcut in (or copy/move the executable to) Program Files -> Startup (not sure if this is the correct name, might differ in different Windows version or different languages).
Edit: O. Lol. I need to press "Submit" faster next time :)
PC startup should be in the BIOS. Not sure where though.
PostPosted: Mon Jul 29, 2013 4:25 pm
thanks Bojcha ! do you know what should i do for my PC starts automatically after a power break down ? windows xp !
No metter what OS, you need to enter bios and search option, (depend on motherboard name is different) something like "Power on after power loss"
PostPosted: Mon Jul 29, 2013 4:26 pm
thanks !!
Vanilla Radio
