 Post subject: Some Screen Options
PostPosted: Sat Jul 20, 2013 11:15 am
This is a screenshot of our Tech Labs Monitor with ST running.
Sorry for the size of the image.
It might be nice to have some screen options that lock "tweakers" out of the controls when you're not looking. :)
Edit: I forgot to add that the top section of the screen is locked and can only be removed with a password. This allows "unauthorised tweakers" to look at the pretty lights as much as they want but not "tweak" anything. Having an option to allow the buttom half of the software go full screen would do the same job, if it could be locked there as well.
Clipper
