PostPosted: Tue May 28, 2013 8:01 pm
http://www.stereotool.com/version_history.shtml
2011/12/12 v6.21 Added multicore support for Declipper and Loudness. Throughput is now 38% higher in presets that use both
2012/12/12 v7.00 Declipper: Improved splitting load over 2 cores
In CLI-version Stereo Tool can enable Multicore processing? (for Declipper)
On my CPU Core i7 (8 threads) is used only single core with an attached settings file (x.sts)
x.sts [45.92 KiB]
Downloaded 527 times
PostPosted: Mon Jun 10, 2013 8:44 pm
Up...
PostPosted: Tue Jun 11, 2013 2:24 am
Sorry for not responding - I read your post and wanted to check it but forgot :(
It *should* work on multiple cores, unless the environment variable NUMBER_OF_PROCESSORS is set to 1 (or less). I'll run a test tomorrow to check what's happening. Anyway, the settings in the .sts file are ok (they should make it work on multiple cores).
PostPosted: Thu Jun 13, 2013 5:02 pm
I have by default: NUMBER_OF_PROCESSORS = 8 (Cores And Virtual Cores)
I will wait ...
PostPosted: Thu Jun 13, 2013 5:20 pm
O wow. It would probably help if I remove the line:
common->MULTICORE = false;
from the command line version..... :)
Done, please wait for the next beta...
PostPosted: Fri Jun 14, 2013 11:23 am
Ok, there was a reason why that line was there - with multicore on the command line version doesn't work. I know how to fix it but it will take some time.
PostPosted: Fri Jun 14, 2013 12:24 pm
ОК
PostPosted: Fri Jun 14, 2013 3:44 pm
Try the Windows version here:
viewtopic.php?f=14&t=4846&start=32
I realized this afternoon that there are 2 types of multi-threading in Stereo Tool:
- Inside filters. For example multiband or clipping is done in multiple threads.
- Some filters at the end of the chain are also multi-threaded. This has very little impact on the performance anymore.
The 'inside filters' multi-threading is now enabled for the command line version and Linux versions.
PostPosted: Fri Jun 14, 2013 5:42 pm
For "stereo_tool_cmd.exe" (v7.22) CPU usage = 12-13%
http://img69.imageshack.us/img69/6144/2x31.png
Fot "stereo_tool_cmd_BETA724-011.exe" (v7.22) CPU usage = 22-23%
http://img10.imageshack.us/img10/1856/txy.png
PostPosted: Fri Jun 14, 2013 5:44 pm
Good, then it uses 2 cores now.
