PostPosted: Fri Apr 19, 2013 10:38 am
How do I fix it ?
Dennis Skoglund
RadioHLR
PostPosted: Fri Apr 19, 2013 1:46 pm
Have you tried enabling 'Synchronize to output sound card' (something like that) in the input sound card settings of Stereo Tool?
If not, I don't have much experience with VAC, but others do... So they might have something more useful to say.
PostPosted: Fri Apr 19, 2013 1:52 pm
More info needed, like.. what vac version, system cpu, OS, configuration .. etc..
PostPosted: Fri Apr 19, 2013 3:54 pm
Version 4.12, Windows7 on a Exi Server whit Intel I 3, and 25 gb ram
PostPosted: Fri Apr 19, 2013 4:48 pm
I will guess that you are not planing to use ST for FM.. but for streaming ...
Open VAC panel and:
- Fix VAC sample rate (SR) to 44100 - 44100 Hz
- Fix VAC bit depth (BPS) 16 - 16 bit
- NC 1..2
- All cables "Stream fmt limit" to "cable range"
- Turn off, channel mixing, PortCls and watermark
- Max Inst 20 - MS per int 1
- Worker threads 2 or 4 (depend on multi and hyper threading of your CPU)
- Prio 31
Also..
- Check CPU usage if U/O flows still occures
- Make sure that 'realtime' is ON is ST
PostPosted: Mon Apr 22, 2013 3:17 pm
excuse my late reply, I have attached a picture http://www.radiohlr.dk/wp/wp-content/up ... 04/vac.png. I still have the problem. My CPU load is 62%
PostPosted: Mon Apr 22, 2013 8:12 pm
- NC 1..2
PostPosted: Sun Oct 27, 2013 4:01 am
Thanks for mentioning this! I would notice that sound would slowly vary over time with high freq's decreasing and weird phasing. I thought it was due to memory leaks of Edcast encoder. I'd reboot it and sound would improve.
After putting a check mark in "synchronize to sound card", sounds stays constant with no strange variations over time on my VAC implementation.
Thanks so much!
PostPosted: Wed Feb 12, 2014 12:25 am
I recently upgraded to the latest VAC. If "Ms per int" is set to 1, I get too much stuttering and clicking. I have to set it to 10 or 15 for non-skipping sound.
With Stereotool, what does CPU usage "Realtime" mean, as compared to the other two settings?
PostPosted: Wed Feb 12, 2014 2:30 pm
"Realtime" is the Windows (task manager) priority "Realtime". It's not really realtime though because Windows isn't a realtime os.
