Stereo Tool Gurus,
Stereo Tool shows Outputs for Normal, FM and Low Quality Low Latency.
This will be my first time trying Stereo Tool On Air using the FM Audio Out with 50us preemphasis. I want Left and Right audio out with the pre-emphasis. I am going to feed the L & R into the STL and try a 15 or 20 minute test during the early hours of the morning and then return the system to its normal processor.
My guess is that the Normal Output always remains Normal. That is, no pre-emphasis on the Normal Output at any time. The FM output would be active when FM and Transmitter are activated. If set to 50us then that FM output would be Left and Right with 50us pre-emph. Normal would still be the normal (no pre-emph) stereo output.
What I experienced was, when I activated FM and Transmitter the Normal went to Mono. What have I done wrong, or is my understanding of what should happen wrong?
I want to do a test of the software on air so I can tick the "Tested" box and purchase the software. It's a magic product.
Regards,
Clipper
(Now Composite)
