Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: testing sound
PostPosted: Tue Apr 02, 2013 4:11 pm
Hello, can annyone my stream checken?
I testing with stereo tool... SA Stereotool 7.10.
Preset - Brian Purity Control Soft (with own settings).
Stream url : http://server-10.stream-server.nl:8604/listen.pls
Winamp : www.radiowaubach.nl/livestream/192/radiowaubach192.pls
Mediaplayer: www.radiowaubach.nl/livestream/192/radiowaubach192.asx
Realplayer : http://www.radiowaubach.nl/livestream/1 ... ach192.ram...
Website : www.radiowaubach.nl
Tnks allready to you....
 Post subject: Re: testing sound
PostPosted: Tue Apr 02, 2013 11:35 pm
tuned in when was track, Major Lazer feat. Busy Signal The Flexican FS Green - Watch Out For This (Bumaye) track on air...
If you ask me, bad...
Downloaded track to be sure.. when there is no deep bass in track, mids and highs goes up.. when there is (should) be deep kicks in track, there are actually gone and whole volume is down ..
I also checked preset you use.. and it's not working like that. It's way better.
PostPosted: Thu Apr 04, 2013 12:27 am
Tnks for you answer.. i working on it. now i have a newer sound..
its allready beter??. I used : optimod 8200 ala drz and parelduikerfm
but i have this preset reset to my own setting.. can you listen again... tnks.
PostPosted: Thu Apr 04, 2013 4:08 am
Not sure why you're using the "soft" one, because that's in the "generic" section, not the "web" section. Generics are generally not for streaming, while the web section presets are for streaming, specifically the MP3 pre-emphasis.
I think Bojcha was trying to say that the built-in preset (my original) works better, but not exactly sure that's what he meant.
Edit: I checked, and apparently the built-in "WEB RADIO STATIONS" version does not have the MP3 pre-emphasis enabled. :shock: I perhaps forgot to do that before I posted it here, because preemphasising causes significant CPU load on my system.
At any rate, Purity Control was an attempt at having bass compressed, but mids and highs be less compressed and/or more limited rather than compressed. It was designed a while ago, before Hans changed to the newer multiband. The newer multiband gives more control than the old multiband, so what I attempted to do can probably now be done with the new multiband.
Whatever you have running right now, at 10:05 PM EDT, with track "Lucky Star" - Madonna, sounds ok. Maybe a little bass heavy, but most of what I do has more bass.
If you want to post the preset file, Bojcha and I can look and see what we think. Alternatively, you might try Cobalt, or Eu4ria II (Bojcha).
- Brian
 Post subject: preset
PostPosted: Thu Apr 04, 2013 7:43 am
Tnks for you .. here is te preset i used on my settings :
http://www.radiowaubach.nl/stereotool/Radio Waubach (TestSound April 2013).sts
PostPosted: Thu Apr 04, 2013 8:41 am
You can find my preset here : viewtopic.php?f=3&t=4764
Excuses. i want i post to this forum, but i have a new topic... @hansheino, kun je mischien even het topic hieronder verplaatsen dank.
PostPosted: Thu Apr 04, 2013 9:22 am
That is absolutely nothing like mine. You're using the new multiband and the new singleband compressors, and have made lots of other changes.
As I haven't used the new compressors, I can't really provide any immediate advice. Perhaps others can comment.
PostPosted: Thu Apr 04, 2013 10:56 am
Ok, me it was about what other of my sound, have random preset downloaded, and this for my taste. now i the the 8100 with dab and fm ... in the new stereo tool.. sorry but my English is not great, this is translated by a random translator on internet. You can check the stream again for me. With the new sound ...?
PostPosted: Thu Apr 04, 2013 7:25 pm
try my drz fat bass v2 ( build in preset) maybe you like that one, its for webradio ;)
PostPosted: Thu Apr 04, 2013 9:10 pm
Heey Studio DRZ. ik ga het proberen :). ben eigelijk op zoek naar de zelfde geluids hoogte van wdr 4, die draaien met een procesor Junger D05
Heb ik uit bronne vernomen.. zou je mischien daar eens instelling van willen maken?.
Dank alvast.
