Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 3 Next
PostPosted: Tue Mar 26, 2013 10:19 am
Hi Mates i have notice a strange cracking sound in my stream i am about 6 hours and i am trying to find a solution but nothing
any help will be appreciate
i use jazler software
vac 4
and st 7.10
edcast standalone
my sound card is sound blaster audigy
here you can listen my stream : http://88.198.16.208:8000/listen.pls?sid=1
thank you in advance !
PostPosted: Tue Mar 26, 2013 10:46 am
Jazler - VAC - Stereo Tool - VAC - EdCast?
My first guess would be VAC but if you use VAC twice that doesn't make much sense. Can you check the buffer fillings in Stereo Tool? Or maybe just increase the output buffer size?
PostPosted: Tue Mar 26, 2013 11:19 am
first of all thank for your help mate !!
i use it like this jazler>>vac1>>stereo tool >>>> vac2>>>edcast
output buffer size 5.000 sec
and buffer fillings ( i don't know if i check right ) is at the middle about 50-55% (if it is a blue bar under buffer size)
PostPosted: Tue Mar 26, 2013 12:26 pm
Ok, that's all ok then, and if it's stable there the CPU load is also not too high. Maybe Jazler has a too short buffer? (Would surprise me but you never know).
This might be a way to find the cause: Play a single beep tone in Jazler, and when you hear crackles, look if you see something in the Stereo Tool waveform. If not, the cause is after Stereo Tool, if there is, it's before.
PostPosted: Wed Mar 27, 2013 8:22 am
i use it like this jazler >> vac1 >> stereo tool >>>> vac2>>>edcast
I try everything i cant find it... cpu load is 47 % also i can't find in jazler where is the buffer size :( i read manual but options for buffer is when you have 2nd soundcard for monitors this thing drives me crazy....
when i am hearing direct from my console sound is briliant but when i hear my stream sound cracking
also i change the way i use jazler what i mean is: (jazler > soundcard output > stereotool > vac1 > edcast )i dont know if it is right..
PostPosted: Wed Mar 27, 2013 2:18 pm
What version of VAC you use?
If latest, Then try to turn off all and...
- adjust "up to" to number of your CPU cores
- "Prio" to 31
- all used cables to fixed rate - or simply check this picture http://i.imgur.com/dy0RVLz.png
- In ST Turn on "Synchronize to output" with default settings.
Also..
- what OS you use? Is it W7 64bt?
- Did you check DPC Latency Checker ?
PostPosted: Thu Mar 28, 2013 10:41 am
- "Prio" to 31
Also..
Hi mate ! and thanks again for your precious help!
I thing now it is ok i change vac settings like your photo and i synchronize to output i believe now it is fine !!
Realy i dont know how to thank you are the best !!! your help was brilliant !! maybe you can check my stream so you can also confirm that is ok now...
Dude Seriously You ROCK !
PostPosted: Thu Mar 28, 2013 1:51 pm
I still hear crackling sounds in it. And all sounds very bad, like there's a bad connection somewhere.
PostPosted: Thu Mar 28, 2013 1:55 pm
Something is wrong with your server. I have ping to there but no audio stream.
PostPosted: Thu Mar 28, 2013 1:58 pm
test it now edcast for some reason crashes omg !!!
