PostPosted: Sat Mar 16, 2013 10:56 pm
Greets!
Does anyone have a preset they are proud of or a suggested place
to start for a station playing today's over the top rock and pop masters?
Looking for roomy bass, clear midrange, and apparent dynamic range...where
none exists to begin with. That's a lot to ask for, I know.
About to make the switch to 7.04.55. Many thanks. Just made the switch to ST and not looking back. :)
PostPosted: Sat Mar 16, 2013 11:04 pm
Well since you are asking for good dynamic range dont expect to be loud.
You can try my R-Type preset (will be also updated soon).. and if still not loud enough you can try to push bit more Advanced clipper.
It's in last betas, just load, and let me know.
PostPosted: Sun Mar 17, 2013 12:18 am
Well, loudness is important too.
Something that compares to Plutonium...to my ears, that preset gives good apparency of dynamic range without hammering everything. Just me, but Plutonium is a fair trade between loud and apparent dynamic range.
To me, there is a difference between real dynamic range and apparent dynamic range.
Much appreciated!!!
