Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: Starting Point
PostPosted: Sat Mar 16, 2013 12:03 am
This preset is based on the new MB and should be a safe, non-aggressive place to start. This preset is based on the concept of playing average program material and adjusting the thresholds to produce roughly equal amounts of g/r in each band, then using an audio oscillator, setting the band mixes to achieve the flattest frequency response. The release time on all MB channels is dramatically reduced and a healthy amount of noise reduction is applied. Substantial amounts of final clipping are employed in response to the slow release time. The sound is clean beyond anything I expected and it's at least as loud (and probably louder) than an Omnia 9 using a slightly enhanced Rustonium preset.
Starting Point.sts [43.43 KiB]
Downloaded 999 times
 Post subject: Re: Starting Point
PostPosted: Sat Mar 16, 2013 1:59 am
Need to check this :)
PostPosted: Sat Mar 16, 2013 8:31 am
AWESOME...
PostPosted: Tue Mar 19, 2013 10:44 pm
Wow! Completely different from all other presets, and a bit too much band 4 and a bit too little band 5 for my taste, but if I switch from this one to any other preset this one wins - according to my ears - consistently :)
PostPosted: Fri Apr 12, 2013 6:45 pm
...what an amazing preset! WOW, just wow! This is... somethin' else! Expecting to see more from you Bob.
And, I want to ask something. Is there any way I can reduce the loudness a little bit without affecting this beautiful rich sound?
PostPosted: Fri Apr 12, 2013 8:07 pm
Wow what a sound!
For me:
adjusted band 1,4,5,6 a bit...
What a nice loud sound without distortion!
PostPosted: Sun Apr 14, 2013 8:29 pm
Nice preset, although the loudness is not created with the multiband. The preset is louder here with the multiband disbabled...
PostPosted: Sun Apr 14, 2013 9:02 pm
That really depends on MB input and output settings!
PostPosted: Mon Apr 15, 2013 8:39 pm
True I guess, but if I import all settings as posted, I reuse the MB input and output as posted in the preset, wright?
PostPosted: Tue Apr 16, 2013 5:48 am
Try bypass or pink noise, this is not true :|
by GAP
"Less is More" (Bob Katz)
