 Post subject: Process Priority
PostPosted: Sun Mar 10, 2013 12:05 pm
Greetings,
I have a question related to a setting in Configuration -> CPU and Latency; Process Priority.
I am using the latest Beta 052. Preset is Impact - by GAP v0.7.
I changed the preset Process Priority setting from High to Normal. I changed the Quality CPU Load setting from 50% to 100%. I also turned on the DeClipper.
I have taken a screenshot, but I can't find how to upload it to the forum, which shows my CPU usage in the Task Manager for Stereotool is 10%. Goes between 9% and about 14/15%.
My question is, if this is all my CPU usage is do I need to use the higher process priority? If so, what do I gain from that?
I am trialing ST for the possible use in 1, maybe 2, FM stations. Is there, or will there be, some documentation that shows what is doing what?
Thanks,
Clipper
 Post subject: Re: Process Priority
PostPosted: Sun Mar 10, 2013 1:17 pm
If you do other things on the pc, for example opening a web browser, Windows might give that priority over processing which can cause hiccups. If you set the priority higher, it does *not* increase the CPU load but it will make sure that Stereo Tool processing gets priority over other things that are happening on the pc. So it's generally a good idea to turn it on.
Now you might wonder why it's an option: If you just listen to some music you probably don't want things like opening a web browser to be slowed down by it. So in that case you could set it to normal.
The documentation is indeed outdated and needs to be updated...
PostPosted: Mon Mar 11, 2013 1:18 pm
Hans,
Thanks for the reply and explanation.
I have set it back to High.
Even though that was my first post I have been following the forums for some time and I have to compliment you on your first class support and the ongoing development of the software.
Regards,
Clipper
PostPosted: Mon Mar 11, 2013 2:41 pm
Thanks ;)
PostPosted: Tue Mar 12, 2013 7:47 pm
we all agree!!
Bart
Web: http://www.contact-dance.com
Request system: http://www.contact-dance.com/c-request
FB page: https://www.facebook.com/ContactDance
