PostPosted: Wed Mar 06, 2013 4:01 pm
Just a minor thing, but I cannot find anything in ST with what I can shift the pilot-phase to compensate phase-imperfections within the RDS-carrier. In Airomate, this is possible:
Airomate-RDS with phase-shift:
StereoTool build-in RDS:
 Post subject: Re: RDS Phase Shift
PostPosted: Wed Mar 06, 2013 4:50 pm
There is: Go to FM sound card -> Calibration. There you can calibrate each frequency - please note that an offset at 57 kHz (RDS) means that there are (probably smaller) offsets at other frequencies as well.
I want to make something better than this in the future - it causes extra latency.
PostPosted: Wed Mar 06, 2013 5:37 pm
Aah, yes - my bad!
Moving the 19 kHz-phase a notch fixed it. Seems that the Trace Alpha I'm using is not as perfect as everybody claims ;) Or it's the exciter that scrambles the phase a bit...
57 kHz and some other frequencies are greyed-out - is that on purpose?
And activating LSB or USB does only bring silence to the right speaker!?
PostPosted: Wed Mar 06, 2013 6:05 pm
It's not Trace Aplpha inperfect but your MPX input at transmitter. It happens all time.
Measuring only TILT in Trace Alpha gives perfect Tilt, but when i wanted to attach it to transmitter Tilt moved, just a bit.
Same with rds and pilot.
- Also, Pira shows "diff", and i always wandered should Pilot or RDS need to be adjusted. Or both.
Activating LSB or USB does only bring silence to the right speaker!?
It's not LSB and/or USB..
It's just used to activate and listen silented channel while adjusting pilot phase to get as minimum sound as possible on silented channel.
