Tnx for your answer.
The last days I did some more testing, and I found that it started to 'hang' after receiving hickups/5 billion cracks.
So first I thought that the 'music program' was crap, but when I listened to the output when stereotool was disabled, then everything was fine
And as soon as I start stereotool, the hickups are starting. (there is enough cpu/memory, new machine).
What I also noticed is when I start stereotol, the oflows/uflows in VAC (Virtual audio cable) is increasing and increasing (and increasing).
Do you perhaps have an idea why stereotool causes so much overflows/underflows in Vac?
(I"m using sample rate of 44.1k , vac as input, vac as normal output, streaming to the universe)
tnx/bedankt
Bart
