 Post subject: newbie
PostPosted: Sun Feb 24, 2013 1:33 pm
Hi, Iam newbie using ST
I heard this ST only for winamp plugin,
now i am intended using ST to process sound of my PC
I downloaded stand alone version, setting input as stereo mix(realtek HD)
normal output is enabled (speaker realtek HD)
please note that iam using single sound card
then the sound is repeatedly after 1 second
what I want is my Pc sound is processed using stereo tool
any clue? is what i did correct ? please help
thanks
 Post subject: Re: newbie
PostPosted: Sun Feb 24, 2013 8:01 pm
Hi..
You need Virtual Audio Cable.
- Set one cable as your windows system default output
- Set same cable as Input for ST Standalone
- Set normal output in ST your soundcard.
PostPosted: Sun Feb 24, 2013 9:59 pm
Yes. Or in the (unlikely) case you have a sound card of the brand ESI, you can use the DirectWire technology in its driver - but for any other card you'll need Virtual Audio Cable.
Why: The stand alone version processes sound card input and sends the result to the output. So, if you're playing music in a CD player, through a mixer, using a microphone etc, that will all be processed.
In case of the sound card, if you use the output as input it will process that - but the result will be sent to the same output and that's why it starts to echo.
O btw - in case your sound card has multiple outputs, using another output for Stereo Tool would also be an option.
PostPosted: Mon Feb 25, 2013 6:30 am
thanks, I'll try it
one more question, is virtual audio cable free?
best regards
PostPosted: Mon Feb 25, 2013 6:41 pm
work great !!!
using virtual audio cable
thanks a lot
PostPosted: Mon Feb 25, 2013 11:22 pm
Unfortunately it's not free... But you've probably already noticed that.
