Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 3 Next
PostPosted: Sun Feb 24, 2013 6:32 am
I could not wait! ... 15 days of holiday and the ST has changed a lot!
This version is very experimental, about 3 hours ... :)
They can think freely about the preset, I'll keep improving it. ;)
Made for ST v7.04 Beta 45
GAP_Impact_v0.1.zip [7.59 KiB]
Downloaded 682 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Feb 25, 2013 5:58 am
Well now a little better ... I think :lol:
GAP_Impact_v0.2.zip [7.98 KiB]
Downloaded 543 times
by GAP
PostPosted: Wed Feb 27, 2013 5:03 pm
Some changes, mainly in the behavior of the bass and the highs.
P.S.: Quality setting is 50%, can upload it to the CPU which give. :)
GAP_Impact_v0.3.zip [7.97 KiB]
Downloaded 546 times
by GAP
PostPosted: Fri Mar 01, 2013 4:11 am
Fixed several "bugs". :)
Spectral corrections and a little more "Power"
Adding Look-Ahead, softer and sensitive. ;)
GAP_Impact_v0.4.zip [8.08 KiB]
Downloaded 571 times
by GAP
PostPosted: Sun Mar 03, 2013 5:05 am
more bass
some corrections
+ Loudness and + constant :twisted:
GAP_Impact_v0.5.zip [8.11 KiB]
Downloaded 528 times
by GAP
PostPosted: Mon Mar 04, 2013 6:15 am
Corrections in the Crossover y band mix, mainly in the two lower bands. :shock:
The mids were pretty uncontroller, did corrections.
Bass more warm!
I would appreciate feedback! ;)
GAP_Impact_v0.6.zip [8.1 KiB]
Downloaded 533 times
by GAP
PostPosted: Thu Mar 07, 2013 8:49 am
You should add more mids, apart from that your preset sounds *very* good for a 9-band
PostPosted: Thu Mar 07, 2013 2:55 pm
Thanks for the comment.
Regarding the mids, as the highs, am making a new version of preset looking for a new way to control them properly.
The coupling is a topic I was hoping to improve it, which is working Hans.
Similarly, I will make a new version, to improve these points, will publish as soon as the end (obviously I'll wait your comments ;) )
by GAP
PostPosted: Sat Mar 09, 2013 9:25 pm
EQ activated.
MB readjusted.
Change the behavior of Single Band, now Highs limiter with sidechain enabled.
Coupling with beta 52.
GAP_Impact_v0.7.rar [9.42 KiB]
Downloaded 535 times
by GAP
PostPosted: Mon Mar 11, 2013 4:23 am
Some fine adjustments to the previous version :mrgreen:
GAP_Impact_v0.8.zip [9.2 KiB]
Downloaded 612 times
by GAP
