PostPosted: Sat Feb 16, 2013 10:59 pm
9 Band version (NEW Multiband) of the BIG O preset.
I use a standalone setup so you probably need to check the IO settings.
Ik like this one best..seems quite consistent.
Please comment!
UPDATED 19/02/2013 >>> Some minor small improvements made
Jeroen.
BIG O by PhantomFM_NEW 9 BAND.sts [62.73 KiB]
Downloaded 790 times
PostPosted: Sun Feb 17, 2013 12:08 pm
I'm definitely going to take a listen but have also been trying out your 5 band preset...
Have you gone to 9 bands now because of consistency problems?
P.S. What genre of music are you testing with? Do you intend to have a less punchy/ dynamic bass?
PostPosted: Sun Feb 17, 2013 2:47 pm
@2Sense, well i like the punchy bass.
If you would like less bass, just slide atack time, band mix and feed forward slider to your needs.
And yes, 9 bands gives a more consistent sound in terms sound collor.
Music i play is mainly 80's and 90's dance (club)
PostPosted: Mon Feb 18, 2013 6:51 pm
sounds awesome on-air with hardstyle!
Adjusted bandmix 65Hz a bit more for some more sub....
Me very happy......
PostPosted: Tue Feb 19, 2013 12:44 am
....And yes, 9 bands gives a more consistent sound in terms sound collor....
This is really a very important statement, because this time it is a real traditional broadcast processing expert who share this opinion.
We had and still have this discussion/disagreement/controversy here how many bands are worth to use.
Many traditional users have stated that more than 7 bands would make things inescapable worse.
So, yes the new multiband (with 9 bands !) is much better than the old (with 10 bands).
But IMO a further reduction of maximal bands would be a fatal decision.
So 9 bands for the MB are ok.
But why not 10 bands as an option if Hans can find a way to fit it in the GUI ?
It could be useful to control certain aggressive hihat and cymbal sounds with a very narrow band without negative impact to other instruments and vocals in the 10-12 KHz range.
PostPosted: Tue Feb 19, 2013 8:49 am
@michi95 It's not that an important statement.
I have worked with the AEV EXCLUSIVE, this was an analog 10 band machine way back in the 90's, it also was verry consistent but hard to adjust properly.
And don't forget VORIS flagship AIRAURA is a 31band limiter machine !
Omnia 9 has selectable bands up to 7
Yes you can make fine sound with only 5 band (see my V2 preset) but 9 bands makes the sound more consistent in sound collor (almost all music has same amount of bass/mid/hights)
PostPosted: Tue Feb 19, 2013 9:18 pm
In this forum it is !
Before you have arrived here :D , it was only DJ-DOGGY and me that voted for more than 7 bands.
PostPosted: Sat Feb 23, 2013 11:03 am
Good job Jeroen.
PostPosted: Sun Jun 02, 2013 1:24 am
Thanks for this great pre-set - I have been trying allsorts of settings to make all of my music sound consistent. This pre-set makes a nice laid back kind of sound - not at all in your face.
