 Post subject: BS-412 Question
PostPosted: Mon Dec 10, 2012 1:19 am
If read the disclamer and the settings it recommends however as much as i would like to adjust for the settings i don't have the faintist idea where i should actuly be aiming for. The Graph is unmarked and i haven't seen anywhere else to look to get the apropiate results.
 Post subject: Re: BS-412 Question
PostPosted: Mon Dec 10, 2012 3:44 pm
Actually this already looks very good (at least the last minute does)
Black line should be close to 0 (top line is 0 dBr, then each line below is 1 dB lower)
Red line should stay as close to 0 as possible as well, if it goes down too far it means the BS412 limiter is reducing the audio which - if more than 1 dB - might become noticeable
The dotted line means that there's bass reduction - do you have Bass Boost enabled in your preset? You get much better results if you turn it off!
Now there's one thing that worries me: The signal never gets anywhere close to 75 kHz (bottom graph). What are you feeding it?
PostPosted: Tue Dec 11, 2012 7:43 am
I dident want my music to clip. The curve off is mainly stop starting music. so its alittle bit quiter and ive adjusted it now that im happy with it.
The following link will take you to the settings that im currently useing. Really appriciate if you would add some constructive critisium to the thread.
viewtopic.php?f=10&t=4401&p=17741#p17741
