 Post subject: slow updates the text
PostPosted: Fri Dec 07, 2012 1:52 pm
Greetings!
I have a program that is why slow updates the text in the radio receiver. it must be so?
It is fast, slow, or do not update. how to configure it properly?
Sound Card Realtek HD
PostPosted: Sat Dec 08, 2012 12:36 am
I do not really understand what you mean. RDS PS or RT update speed? Could you please describe exactly what's happening?
PostPosted: Sat Dec 08, 2012 12:42 am
Update rate of the text on the receiver ... then slow, then fast
PostPosted: Sat Dec 08, 2012 12:52 am
Yes but which text - RDS PS or RT? And what are you sending out? Can you paste your text as you've entered it in the Stereo Tool GUI here?
PostPosted: Sat Dec 08, 2012 1:22 am
PostPosted: Sat Dec 08, 2012 5:43 am
More info! What transmitter, how is it connected, what receiver, what text - PS text or Radio Text .. etc.. [?]
btw, you have 1 work in PS Text, so it might be Radio Text then..
If so, instead 2s set 20s.
PostPosted: Sat Dec 08, 2012 2:20 pm
Hlly TX 30s Fm Transmitter
