PostPosted: Tue Jun 12, 2012 4:24 pm
I was thinking of using stereotool as a microphone proccessor, both for creating jingles, small voiceovers etc, and for long podcasts/talk shows.
If stereotool is able to generate such a loud, clear, exciting sound for music, I bet it could do the same for voice.
So any ideas, suggestions and presets for this?
Also how should the input signal be like? I was thinking of using some very light compression with noise gate before using stereotool.
PostPosted: Wed Jun 13, 2012 9:31 pm
I made a preset for voice, but never had the same feedback, you can find in viewtopic.php?f=10&t=4189 ;)
Try and make me your comments
by GAP
"Less is More" (Bob Katz)
PostPosted: Thu Aug 02, 2012 11:12 pm
I have pending update the preset for the new release of ST v6.32. :|
by GAP
