PostPosted: Sun Jun 10, 2012 6:37 am
Bug that's affecting the Attack and Release speeds of Single Band Compressor in AGC Mode.
Any change in UI of StereoTool makes the Single Band Compressor read attack and release speeds of Non-AGC mode instead of AGC mode. While loading a preset the first instance, the filter does read the AGC mode speeds, but soon discards them and reverts to Non-AGC mode speeds.
As a work-around, I am assigning same attack and release speeds in sts file to both AGC and Non-AGC modes.
This bug can be reproduced in VST plugin of Stereo Tool v 6.31.
visit website
PostPosted: Sun Jun 10, 2012 1:40 pm
Hm, so far unable to reproduce. Have to leave now, will try again later today or tomorrow.
PostPosted: Mon Jun 11, 2012 1:03 pm
To make your life easier as far as reproducing this bug is concerned, I am posting a snippet for the Single band compressor settings.
[Singleband Compressor]
Enabled=1
AGC RMS style Enabled=1
AGC RMS style Attack speed=0.000005847282
AGC RMS style Decay speed=0.0003169642
AGC RMS style Target RMS level=61520
Attack speed=
Decay speed=
AGC RMS style Remove remaining peaks above=1.4142135623730950488016887242097
As you have noticed, I have intentionally left Attack and Release speeds for the non-AGC mode unassigned which means the compressor will revert to default values - only in non-AGC mode.
Let me know what happens when you use a preset with this AGC setting in Stereo Tool VST plugin.
visit website
PostPosted: Mon Jun 11, 2012 5:13 pm
Ah, it went fine here until I did a reload, then one of the parameters changed, then I clicked on some other things and the other changed as well. Will check what's wrong.
