PostPosted: Sun Jun 03, 2012 7:54 pm
When trying StereoTool just to correct azimuth only I found that it is hard to disable all not wanted sound processings (to get a clean sound). Currently the settings are distributed across a wide amount of sub-menus.
It would be very helpfull for beginners to add a central option panel, where all processing sections could be switched on or off.
[x] STEREO IMAGE
   [x] Aizmuth and Channel Delay
   [ ] Stereo Boost on
   [ ] Stereo Image / Flat Stereo
[ ] AUTOMATIC GAIN CONTROL
   [ ] AGS
   [ ] Bass AGC
[ ] NOISE GATE
   [ ] Noise gate (removal)
   [ ] FM Stero hiss removal
[ ] BANDPASS FILTER
[ ] BASS BOOST
[ ] MULTIBAND COMPRESSOR
[ ] LIMITING AND LOUDNESS (FINAL LIMITER)
   [ ] Singleband compressor/limiter
   [ ] Phase rotation
   [ ] Final clipper
   [ ] Hard limit
   [ ] BS-412
   [ ] Lossy compression
[ ] DECLIPPER
[ ] FM TRANSMITTER
   [ ] RDS Encoder
   [ ] Stokkemask
   [ ] Direct soundcard access
Infact I wrote the above list to help myself where to find and switch off the varous options.
