PostPosted: Sat Apr 21, 2012 11:41 am
I'm not sure if the problem is in Stereotool or my soundcard/pc is the problem. (using the emu 0204 usb soundcard)
The problem accurs with asio enabled. Without asio there is no problem.(but I want asio hehe :P )
When I'm using a preset with a samplerate of 48Khz or just start stereotool with no preset(reset) and I want to load a preset for fm (192khz) stereotool will shut down (error).
When I load a 48khz preset and want to change the samplerate it will work fine till 128 khz, but when I change it for example from 128khz to 176Khz or 192Khz stereotool will shut down. (error)
The only way I can load a preset with a samplerate of 192 Khz is to startup stereotool with no preset loaded(reset) and there I have to change the samplerate already to 192Khz and than I can load a fm preset (samplerate 192khz).
PostPosted: Sun Apr 22, 2012 9:20 am
What error do you get? Stereo Tool should NEVER shut down!
PostPosted: Sun Apr 22, 2012 11:10 am
I made 2 printscreens, It doesn't say what the error is...
Maybe the problem is with the emu card, shouldn't be, because till the samplerate of 128khz everything works fine...
The emu card take some time to lock the samplerate (automatic) but before the emu has locked the samplerate (in this case only with 176.4 or 192khz), stereotool is already shutting down. The only way I can set the samplerate to 192 Khz is as I described above.....
