 Post subject: uninstall
PostPosted: Thu Feb 12, 2009 11:57 am
the program is great, but my cpu not.
I want to uninstall stereo tool but I can´t find the program on my program files.
plz help me, thx
schwarm
 Post subject: Re: uninstall
PostPosted: Wed Feb 18, 2009 10:02 am
Hi Schwarm,
I assume you're using the Winamp plugin version?
If so, you can uninstall it in Winamp. Right click -> Preferences -> Plug-ins -> DSP Plug-ins, then select [None] and Stereo Tool won't be loaded anymore.
If you want to really remove it, just delete dsp_stereo_tool.dll from the Winamp plugins directory (usually C:\Program Files\Winamp\Plugins\dsp_stereo_tool.dll). This is the only file that Stereo Tool installs.
