 Post subject: S.T. with WINDOWS 7
PostPosted: Fri Apr 13, 2012 10:34 am
Hi , i make a format and i put the win 7 and i have a problem with the sound ! i have a small glitches every 30 or 50 sec ! i try deferent version both winamp and s.t. always as ' winamp plug in ' but the problem remane ! before the win 7 i used to have vista and everything works fine !
can you help me ?
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
 Post subject: Re: S.T. with WINDOWS 7
PostPosted: Fri Apr 13, 2012 11:17 pm
Few questions:
- In the Winamp version, are you using Direct Sound Card Access (for FM output)?
- What happens if you run Winamp without Stereo Tool?
My first guess would be that there's something in your Windows 7 install that conflicts with the sound card.
I know that there's a program with which you can see hiccups in the hardware, but I forgot the name.... (Anyone?)
PostPosted: Sat Apr 14, 2012 4:28 am
DPC Latency Checker
http://www.thesycon.de/deu/latency_check.shtml
Let it run, while you use ST, if you are in green all the time, then problem is somewhere else (not hardware)
PostPosted: Sat Apr 14, 2012 4:14 pm
Few questions:
Well sorry but i run it like a plug in on that computer ! with out s.t. i have no glitches !
Vanilla Radio
PostPosted: Sat Apr 14, 2012 4:15 pm
DPC Latency Checker
i check it and everything its on green !
Vanilla Radio
PostPosted: Sun Apr 15, 2012 12:45 am
In that case, can you check the CPU load? It might help to increase the Winamp audio buffer size.
I will be in Las Vegas next week, so it might take some time for me to respond... (But others will probably respond instead).
