PostPosted: Mon Mar 26, 2012 4:19 pm
A preset was due for some time ever since I began working with an altered approach with AGC and Multiband sections.
Quick Summary:
The preset is largely intended for home listening, transcoding processed tracks and so on. I can not tout this as a Web Radio preset (yet) because of level difference across dense and dynamic tracks. The expense is intentional to achieve the effect(read spectral balance) I desired.
For generic usage, the default MX12 preset should impress you. It's true to the original source with absolutely no coloration(could be good or bad to the end user) as perceived on my gear. Sound is exceptionally clean.
File comment: Mirage MX12 [Default]
Mirage MX12.zip [1.97 KiB]
Downloaded 1020 times
Those who have a fetish for bass, can try out the Hyper Bass version. I can draw an analogy of this preset to Sony Walkman's Mega Bass effect.
File comment: Mirage MX12 Hyper Bass
Mirage MX12 Hyper Bass.zip [1.99 KiB]
Downloaded 860 times
Feel free to do an A/B comparison with some other presets and let me know what you think of this attempt.
[Created and tested using VST plugin beta 29 ver 6.22 hosted on J River Media Center 17]
visit website
PostPosted: Tue Mar 27, 2012 2:30 am
Web Preset : Mirage MX20
Consistency across entire audio spectrum and across sound tracks. Tested on beta 32 ver 6.22 VST plugin.
File comment: Mirage MX20 Web-Radio
Mirage MX20.zip [2.06 KiB]
Downloaded 979 times
visit website
PostPosted: Tue Mar 27, 2012 3:04 am
Very good preset sounds very nice on web streaming :P
http://www.kanal80.net
Best 80's & 90's Music
PostPosted: Tue Mar 27, 2012 7:37 am
Very, very good preset. I'd like MX12, more natural and neutral sound. Excellent!
PostPosted: Tue Mar 27, 2012 9:44 am
Thanks a lot guys for the feedback. Glad you liked my work.
@Jony: I was doing a comparison with other streams on AOL music and Armin Van Buuren's ASOT web cast. The radio preset MX20 sounds way better than them and has punch in it.
@ Popaj: I will publish a minor update to the reference preset MX12 tonight which I tested on beta 32 VST. With that, I find very little or no difference in texture of the sound from the original track.
visit website
PostPosted: Tue Mar 27, 2012 3:53 pm
" The radio preset MX20 sounds way better than them and has punch in it "
That's true, i finaly left the Omnia6 and adopted this one for my main stream.
Nice work
PostPosted: Tue Mar 27, 2012 8:35 pm
And again that bass ringing caused but badly adjusted phase-rotator.
Seems listening too much orban (ultra non-phase-linear processing) sound has big consequences. :p
Preset is anyway not bad, soft Limit like this http://i.imgur.com/HCDLC.png but i guess that gives some characteristics, and ofcourse default settings for phase rotator.
PostPosted: Sat Mar 31, 2012 12:48 pm
+1
PostPosted: Tue May 29, 2012 10:07 pm
Hi phoenix, is it possible that you update the web preset Mirage MX20 for 6.31
I realy like this preset, but i think it needs an update so it works better With 6.31-013A
thanks
