 Post subject: Vive La France
PostPosted: Thu Mar 22, 2012 10:05 pm
Hi Everyone,
I'm new to this forum and recently started working with Stereotool after getting sick and tired of my own VST plugins-chain which I used and tweaked for over 12 Years.
I've always been in love with the smooth and phat sound of the french radio stations but on the other hand I didn't like the pumping sound they had. Something I always try to get back in my presets.
Attached you will find my first preset (for V6.21) I would like to share with you: Vive La France.
It is based on Phoenix' BBC preset and tweaked to get a phatter sound. Works very fine on dance music for example.
The preset has been designed to create a certain sound only and therefore has not been tested on FM. You can probably tweak it a lot to create more loudness and make it useful for FM.
Enjoy!
Vive La France.zip [3.8 KiB]
Downloaded 837 times
 Post subject: Re: Vive La France
PostPosted: Thu Mar 22, 2012 10:40 pm
Not bad preset... just bass is "ringing" (phase rotator)
PostPosted: Thu Mar 22, 2012 10:49 pm
Thanks. It's meant to be like that (the french loved it) but you can increase the initial speed and change the start freq to get rid of the artifacts.
