 Post subject: Freeze
PostPosted: Sat Jan 17, 2009 7:06 am
Hi Hans, use the latest version of stereo Tool and I realized my system freezes (Vista Ultimate 32 Bit)
use Fm transmitter :cry: is a sin,what can 'depend?.
sorry my bad englaise :| google traduttore
 Post subject: Re: Freeze
PostPosted: Sun Jan 18, 2009 3:05 am
Hello Salvo,
Could you please try to answer the following questions?
1. What exactly does "freeze" mean? Is the CPU load too high? If so, you could try the following things:
- Set the Quality to "Low".
- Disable "Multiband HQ".
- If that is not enough, set Loudness to 1.00.
If that didn't solve the problem:
2. Which version of Stereo Tool are you using? Stand alone, Winamp or VST?
3. If you're using the Winamp plugin, what kind of files are you playing? There is a bug in the WAV files input plugin of Winamp which can cause Winamp + Stereo Tool to freeze in some situations. MP3s should run fine.
PostPosted: Sun Jan 18, 2009 12:32 pm
Hello Salvo,
thanks for the answers,I think that both the CPU..using the latest version! for winamp and SamBroadcaster .the low quality solves!which version do you recommend?
Thanks a good week
PostPosted: Thu Mar 26, 2009 1:07 pm
I'm experiencing freezing of Stereo Tool 3.40 using the latest Winamp (Vista 32-bit).
The sound still plays but Stereo Tool loses responsiveness (can't change options, buttons go black, can't open or close the window).
So far I haven't worked out the cause, and it's happened even when I try disabling features and using low-cpu.
Any ideas?
PostPosted: Thu Mar 26, 2009 1:25 pm
Does this always happen (immediately?), or only sometimes? And does it happen if you're not playing music?
Do you know if the freeze starts when Winamp switches to the next track (that has been a problem in the past that SHOULD have been solved a long time ago...)
When the freeze occurs, are the volume bars etc. still being updated?
PostPosted: Thu Mar 26, 2009 3:24 pm
Only happens sometimes during the playing of music.
Music continues to play and yes the volume bars are displaying, otherwise I can't change anything or close the plugin.
I switched to 3.30 and the problem has happened once since... if I spot a pattern I'll let you know.
PostPosted: Thu Mar 26, 2009 3:30 pm
Oh and another freeze happens when I press configure plugin under DSP/effect in preferences.
