 Post subject: Strange problem
PostPosted: Mon Feb 27, 2012 1:41 pm
I don't know if this is the right place to post this topic, but sometimes when i listen to a song there is a strange sound (pop i think is the word) You can hear it here - http://www7.zippyshare.com/v/87351482/file.html especially at the beginning of the song
I tried with older versions of stereo tool, but the sound didn't stop.
Now i'm using the 6.22 beta
Soundcard: Realtek HD Audio
Sam Broadcaster v4.91
PS: Sorry for my english... :mrgreen:
Edit: I forgot to say that i set the SAM Broadcaster to use all the 4 cores of the CPU :)
Edit2: I fixed it, just increased the buffer time in Sam broadcaster and now the problem is gone :) If you want delete the theme :)
 Post subject: Re: Strange problem
PostPosted: Mon Feb 27, 2012 4:03 pm
i see that you created that clipped_bass_after_soft_part. :)
PostPosted: Mon Feb 27, 2012 6:58 pm
Yes, i had to edit the *.sts file with Notepad++ and it worked :)
