PostPosted: Mon Feb 13, 2012 7:28 pm
Testing some values ​​in the configuration file (sts), I managed to do that in the ST fewer bands can be used in the MB. :roll:
I enclose a sample preset, which are used only 7 bands.
Hans can tell me if everything works ok, or is there an error in the tuning of ST?
What is not, as is the bandwidth of each filter based on the band center frequency.
The values ​​changed in the MB section are:
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5750
Maximum volume - Band 0=6250
Maximum volume - Band 1=6750
Maximum volume - Band 2=6500
Maximum volume - Band 3=5750
Maximum volume - Band 4=4500
Maximum volume - Band 5=2500
Maximum volume - Band 6= -1
Maximum volume - Band 7= -1
Maximum volume - Band 8= -1
Attack speeds linked=0
Attack speed - Band -1=0.000026008
Attack speed - Band 0=0.000032212
Attack speed - Band 1=0.000032212
Attack speed - Band 2=0.000032212
Attack speed - Band 3=0.000034489
Attack speed - Band 4=0.000034489
Attack speed - Band 5=0.000043308
Attack speed - Band 6=0
Attack speed - Band 7=0
Attack speed - Band 8=0
Decay speeds linked=0
Decay speed - Band -1=0.000314613
Decay speed - Band 0=0.000314613
Decay speed - Band 1=0.000539601
Decay speed - Band 2=0.000539601
Decay speed - Band 3=0.000728166
Decay speed - Band 4=0.000728166
Decay speed - Band 5=0.000958171
Decay speed - Band 6=0
Decay speed - Band 7=0
Decay speed - Band 8=0
Above Top Limiter=0.709999979
Clipping enabled=1
Postprocessing enabled=1
Flat frequency response enabled=1
Relative clip position - Band -1=2.508771658
Relative clip position - Band 0=2.508771658
Relative clip position - Band 1=2.508771658
Relative clip position - Band 2=2.508771658
Relative clip position - Band 3=2.508771658
Relative clip position - Band 4=2.508771658
Relative clip position - Band 5=2.508771658
Relative clip position - Band 6= -1
Relative clip position - Band 7= -1
Relative clip position - Band 8= -1
Final limiter value=1
Final limiter decay speed=0.00076116
Final limiter clipping=1
Channel separation steepness protection enabled=1
Channel separation steepness (maximum artifact strength)=0.25
Voice protection strength=1.350000024
Band 1+2 locking strength=0.25
Equalizer enabled=1
Equalizer position - Band -1=1.197802305
Equalizer position - Band 0=1.127659559
Equalizer position - Band 1=0.941747665
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1.127659559
Equalizer position - Band 5=1.222222328
Equalizer position - Band 6= -1
Equalizer position - Band 7= -1
Equalizer position - Band 8= -1
Center frequency - Band -1=80
Center frequency - Band 0=160
Center frequency - Band 1=450
Center frequency - Band 2=1000
Center frequency - Band 3=3000
Center frequency - Band 4=6000
Center frequency - Band 5=12000
Center frequency - Band 6= -1
Center frequency - Band 7= -1
Center frequency - Band 8= -1
Try to load the preset, but not recorded from the ST, because there are values ​​that change other than what they are.
GAP_ 7_Bands.zip [4 KiB]
Downloaded 721 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Mon Feb 13, 2012 9:25 pm
That will not going to work ! :)
you think i didn't try? :D
I want less bands too. Yes 7 maybe even 6.
PostPosted: Mon Feb 13, 2012 9:59 pm
have you tried the preset attachment :?:
by GAP
PostPosted: Mon Feb 13, 2012 10:09 pm
of course..
only way to turn band(s) is to move it away from 192kHz so 200kHz+, also "prevent Artifacts" must be OFF (250%), and only one (last) band can be removed safely, and even that is not 100% solution.
PostPosted: Mon Feb 13, 2012 11:49 pm
not 100% solution, I think that not everything is resolved, but close enough :|
by GAP
