PostPosted: Tue Jan 03, 2012 11:55 pm
I'm using stereo tool command line in Windows 7, Pentium Centrino Duo T5600 1,83 GHz, streaming through Subsonic. The thing is that after some minutes it stops working, and Resource Monitor shows 100% CPU usage (the preset does no use loudness nor the declipper) and 3 images of stereotoolcmd.exe, each with 4 threads, and around 30 of CPU each. Subsonic itself, as a service, shows up around 85 CPU. Any clue as to if that is normal? Thanks,
DJC
PostPosted: Wed Jan 04, 2012 12:59 am
Hm, I don't know Subsonic (I actually had to look it up) - but my first question would be: Why are there 3 instances of Stereo Tool present? Or are you streaming 3 streams simultaneously?
30% per Stereo Tool instance doesn't seem out of the ordinary, but 3*30+85 is more than 100 so that doesn't make sense? Also, 85% for just a streaming service seems a lot - does it start this high or does it get this high when it gets stuck? And when it does, are the Stereo Tool instance still doing anything?
PostPosted: Wed Jan 04, 2012 2:40 am
That is part of the odd thing. There is just one stream (unless I'm been hacked, which seems very very unlikely, but I could check in the log file). Something similar has been happening when I listen to music, after some minutes the music starts to interrupt, or if I process files, I start at almost 4x and then it gets as slow as 0,6x. When that happened (3 instances) sound just stopped (in my Iphone) and performace went all up to 100% steady in my PC. This didn't happened with earlier versions. I also ran a complete malware cleaner, which found something but overall nothing changed that much.
I asked also because ordinarily when using stereotool without loudness CPU doesn't reach 30, it was around 15
Edit: this is the log file
[1/3/12 7:58:40 PM CLST]
DEBUG
InputStreamReaderThread
(c:\subsonic\transcode\stereo_tool_cmd) 38712K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛß ÛÛÛÛ ÛÛÛÄ ÛÛÛÛÄÄÄ ÛÛÛÛÛÛÛ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38720K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛß ÛÛÛÛ ÛÛÛÄ ÛÛÛßÄÄÄ ÛÛÛÛÛÛß
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38728K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛß ÛÛÛÛ ÛÛÛÄ ÛÛÛÄÄÄÄ ÛÛÛÛÛÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38736K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÛ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛßÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38744K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄÄÄÄ ÛÛÛÛÛÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38752K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄÄÄÄ ÛÛÛÛÛÛÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38760K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÛÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38768K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÜÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38776K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ßÄÄÄÄÄÄ ßÄÄÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38784K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛßÄÄÄÄ ÛÛÛÛßÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38792K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÛÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38800K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÜÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38808K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛßÄÄÄÄÄ ÛÛßÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38816K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÜÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38824K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛß ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÜÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38832K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÜÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38840K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38848K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ßÄÄÄÄÄÄ ßÄÄÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38856K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÛÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38864K ÛÛÛÛ ÛÛÛÛ ÛÛÛÜ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÛÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38872K ÛÛÛÛ ÛÛÛÛ ÛÛÛÜ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛßßÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38880K ÛÛÛÛ ÛÛÛÛ ÛÛÛÜ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38888K ÛÛÛÛ ÛÛÛÛ ÛÛÛÜ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÛßÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38896K ÛÛÛÛ ÛÛÛÛ ÛÛÛÜ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛßÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38904K ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÛÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38912K ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛßÄÄÄÄÄ ÛÛÛßÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38920K ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ßÄÄÄÄÄÄ ßÄÄÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38928K ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛßÄÄÄÄ ÛÛÛßßÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38936K ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÜÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38944K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38952K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄÄÄÄ ÛÛÛÛÛßÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38960K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÜÄÄÄ ÛÛÛÛÛÛÜ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38968K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÜÄÄÄÄ ÛÛÛÛÜÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38976K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÄÄÄÄÄ ÛÛÛÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38984K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÜÄÄÄÄ ÛÛÛÛÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 38992K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ßÄÄÄÄÄÄ ßßÄÄÄÄÄ
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 39000K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÛÄ ÛÛÜÄÄÄÄ ÛÛÛÛÜÄÄ
[1/3/12 7:58:42 PM CLST]
DEBUG
(c:\subsonic\transcode\lame) LAME 3.98.4 32bits (http://www.mp3dev.org/)
DEBUG
(c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE (ASM used), SSE2
DEBUG
(c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
DEBUG
(c:\subsonic\transcode\lame) Encoding to
DEBUG
(c:\subsonic\transcode\lame) Encoding as 44.1 kHz j-stereo MPEG-1 Layer III (11x) 128 kbps qval=3
DEBUG
(c:\subsonic\transcode\lame) Error writing mp3 output
DEBUG
(c:\subsonic\transcode\stereo_tool_cmd) 39008K ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛÛ ÛÛÛß ÛÛÛÄ ÛÛ
DEBUG
[1/3/12 9:24:32 PM CLST]
INFO
PodcastService
Starting scheduled Podcast refresh.
INFO
PodcastService
Completed scheduled Podcast refresh.
[1/4/12 12:06:20 AM CLST]
INFO
VersionService
Resolved local Subsonic version to: 4.4
INFO
VersionService
Resolved latest Subsonic final version to: 4.6
INFO
VersionService
Resolved latest Subsonic beta version to: 4.6.beta2
