 Post subject: Thanks Hans
PostPosted: Wed Dec 17, 2008 5:27 am
Hi,I tested this great software it works well!I would like to thank the creator of ...StereoTool.Only one thing does not work with Realtek ,I hope in the near Update.
Merry Christmas to all...and thanks again Hans :)
 Post subject: Re: Thanks Hans
PostPosted: Wed Dec 17, 2008 10:38 am
Welcome Salvo! Thanks for your thanks :shock:
What do you mean by "it does not work with Realtek"? Have you tried the settings described on this page: http://help.stereotool.com/fm_transmitt ... card.shtml ? I have received confirmation from several people that they got it to work on an ALC883 with these settings.
Stereo Tool has no control over sound card peculiarities, so if it doesn't work with the current version of Stereo Tool, it also won't work with future versions. (On the other hand, if it works but the stereo or RDS signal is bad, you can try the FM Transmitter Calibration settings at the bottom right of the FM settings window to improve it).
PostPosted: Wed Dec 17, 2008 2:22 pm
Hi, thanks again,I installed Realtek High Definition Audio Codecsfor my system Vista Ultimate changing @ 192,Rds Not Work,is not important works with the audiodriver HDA that autoinstall Vista.It is perfect
a prize for the inventor of Stereo Tool
