 Post subject: GAP_BsAsCity - ST v6.21
PostPosted: Thu Dec 22, 2011 9:30 pm
With the coming of a new year again, back to the preset GAP_2011 let them present a new preset.
GAP_BsAsCity (BsAs = Buenos Aires) is ideal for all types of music, it adapts to every rhythm, with clear sound, deep and sweet.
I hope you enjoy it, I hear any comments you may have.
The preset is made with 6.21 ST
Happy New Year :!: :!: :!:
File comment: for ST v6.21
GAP_BsAsCity_v0.1.zip [4.1 KiB]
Downloaded 1188 times
by GAP
"Less is More" (Bob Katz)
PostPosted: Wed Jan 04, 2012 12:10 am
Hey, happy birthday (saw it on the forum home page). Thanks for your great preset, being version 0.92 the best one IMHO.
PostPosted: Wed Jan 04, 2012 2:53 am
Thank you very much !!! DJC ;)
by GAP
PostPosted: Mon Jan 16, 2012 4:25 am
I leave with a new version, which I corrected some minor (and not so minor ...) in various modules.
Changes in the Bass Boost, Bass richer in harmonics.
EQ adjustments.
Corrections in the MB, for a flatter spectrum and consistent.
Settings on the Single Band compressor.
I hope they like, greetings. ;)
GAP_BsAsCity_v0.2.zip [4.07 KiB]
Downloaded 926 times
by GAP
PostPosted: Mon Jan 23, 2012 4:02 am
More consistent loudness.
Improved spectral.
Tunning the phase rotation.
Other adjusts.
Regards ;)
GAP_BsAsCity_v0.3.zip [4.08 KiB]
Downloaded 876 times
by GAP
PostPosted: Fri Feb 03, 2012 5:18 am
New changes:
AGC tunning
Constant Loudness all time!
EQ setting for signature
Lossy Compression on, for old records
Fine Adjusts in general.
GAP_BsAsCity_v0.4.zip [4.09 KiB]
Downloaded 1007 times
by GAP
PostPosted: Fri Feb 03, 2012 1:53 pm
Hello gpagliaroli , i use your preset for my little webradio , sound very good , thank you for your work ;)
If you want listen the result ; www.radiopop.fr.st :)
PostPosted: Fri Feb 03, 2012 3:05 pm
A pleasure to use my preset!
I will listen, when I get home. ;)
by GAP
PostPosted: Tue Feb 07, 2012 4:25 am
If you want listen the result ; http://www.radiopop.fr.st :)
sounds good !!! :lol:
by GAP
