PostPosted: Tue Nov 29, 2011 8:27 pm
Hello,
i found a problem with a very high distortion in Songs with Piano Instruments. Such as "children" from robert miles or "if a song can get me you".
if you use the Default "Web Radio (Loud)" Preset and only change the "Loudness" Slider to the highest value you can hear in the highs very much distortion. i try to use the settings for the extreme highs protection but it seams no difference.
Do you have any Idea how to make Piano sounds very fine on the highest loudness setting?
PostPosted: Thu Dec 01, 2011 10:59 pm
i just checked "children" and i did't notice much distortion on piano with that preset. Anyway you can try:
- First. check your original file.
- Turn on Bandpass 30-22kHz (never phase linear)
- set "Do not reduce bass below" (loudness section) to 60%
PostPosted: Sun Dec 04, 2011 5:04 pm
I tryed it again with another Version. You have been right the distortion was in the file i used! thanks for your tip
PostPosted: Sun Dec 04, 2011 11:47 pm
You could try if the declipper helps in that case. It might fix it!
