 Post subject: Bug in 6.20 VST Version
PostPosted: Tue Nov 29, 2011 8:17 pm
Hello,
there is a Bug in the current Version of Stereotool. When you save a Preset as STS and load it again the Controler for the loudness is if the value was before > 3 always at the value of 3.
The same occurs if you create a new VST Session, when the last Setting is loaded automatically. Then the Value is also always 3.
Can you fix this Please?
Thanks
PostPosted: Wed Nov 30, 2011 12:02 am
Confirmed, I was clipping the value between 1 and 3. Now clipping between 1 and 4.
PostPosted: Wed Nov 30, 2011 7:14 pm
Wow thats fine, thank you hans. do you replaced the VST Version on the Homepage? (The Date of the Download did not change)
PostPosted: Wed Nov 30, 2011 10:31 pm
No not yet, check the 6.20 thread in the News section because all the bugs were reported there as well.
I will post another update tonight.
