PostPosted: Thu Jun 19, 2008 10:51 pm
I'm trying out the command line version of Stereo Tool 3.14, but whatever I do it allways crashes. The output I get before the fcrash is this:
--8<--
STEREO TOOL 3.14 CONSOLE APPLICATION - (C) HANS VAN ZUTPHEN, 2001-2008
Converting .\house.wav to .\w.wav using settings from .\Portable.sts
AMPLIFICATION:
pre amp: 3.00*
post amp: 1.00*
STEREO: ON
phase amp: 0.00*
width amp: 1.00*
extra phase: +0°
mono<->stereo: 0.00 (-1 mono only...+1 stereo only)
DUALBAND: ON
maxval: 5380 6260
upspeed: 0.00004 0.00004
downspeed: 0.00040 0.00040
MULTIBAND: ON
maxval: 5380 6260 6750 6940 6850 6310 5670 4990
upspeed: 0.00004 0.00004 0.00004 0.00004 0.00004 0.00004 0.00004 0.00004
downspeed: 0.00040 0.00040 0.00040 0.00040 0.00040 0.00040 0.00040 0.00040
Encountered RIFF/WAVE header "fmt ", copying 16 bytes
Encountered RIFF/WAVE header "data", processing 36628156 bytes
--8<--
After this Windows tells me stereo_tools_cmd.exe has encountered a problem and needs to close and shows this error signature:
AppName: stereo_tool_cmd.exe
AppVer: 0.0.0.0
ModName: stereo_tool_cmd.exe
ModVer: 0.0.0.0
Offset: 000047f1
Does anyone have a wav file that is tested to work with the command line version that I can test it with?
If there's a debug switch/version of the command line tool I can try to get somk more info on the problem.
Regards
/Jonas
PostPosted: Fri Jun 20, 2008 12:17 am
WAAH! I just tested it and it crashes here all the time too... Will look into it asap!
PostPosted: Fri Jun 20, 2008 1:03 am
I've compiled a new version, it can be downloaded now.
My apologies for the inconvenience. I had made a change to the Stereo Tool processing between versions 3.13 and 3.14, but I never realized that it would impact the command line version also. So I completely forgot to test it before uploading it. :o As in "It builds, let's ship it"...
I will add an automated test of the command line version which will be ran automatically before a version is uploaded to avoid this type of problems for future versions. Thanks for notifying me of this problem.
Note: When using the command line version, you need to specify the FULL PATH to the sts file. So .\Profile.sts won't work - you really need to use something like C:\blabla\Profile.sts ! (For the input and output files, you can use relative paths without problems).
Hans
PostPosted: Fri Jun 20, 2008 1:34 am
That was fast!
Many thanks.
The newly uploaded version works fine here. Now I'm off to experiment with the tool. :-)
Regards
/Jonas Eckerman
