 Post subject: New Version:)
PostPosted: Sun Nov 13, 2011 4:44 pm
Thank you Hans for the new version of stereo tool!! I greatly enjoy it and it sounds wonderful. How are we able to change the number of bands in the multiband compressor? Also, what are the ITU-BS 1770 supports used for? I am not familiar with this. Thanks!
 Post subject: Re: New Version:)
PostPosted: Tue Nov 15, 2011 4:26 am
1. You cannot change number of MB bands. (for now)
2. hmm.. try this..http://www.google.rs/url?sa=t&rct=j&q=i ... NA&cad=rja
PostPosted: Thu Nov 17, 2011 11:54 pm
Well, you can set the highest band(s) frequencies very high in the STS file, outside the audible range. That would in effect turn them off.
About ITU-1770: That's a standard that takes into account the human hearing: Certain frequencies "sound" louder to us even though they are not. If you turn this on the apparent volume will stay more equal, even though the energy is less equal.
