PostPosted: Fri Oct 28, 2011 12:36 am
I still think (agree with someone that has asked for this change too), that the GUI value change resolution in Multiband for +/- EQ gain and Clipping (relative to soft limit) settings is too unsubtle (I have to manually edit the STS presets to test smaller steps).
All other settings in Multiband have very fine value change resolutions (using the mousewheel or the arrow keys of the keyboard) - some even with multiple 00000 values ! (I like it this way - if you do not have the time you can always use the mouse pointer instead to drag the slider in the GUI) !
For both (+/- EQ gain and Clipping) I would recommend to have a value change resolution of +/- 00.01 using the mousewheel.
If anyone do not need such small steps he/she can use the mouse pointer to drag the slider in the GUI.
PostPosted: Fri Oct 28, 2011 8:45 am
Bah... I can just push the wheel on my Logitech MX Revolution and go into free spin mode... :ugeek:
Dragging is for Drag Queens... :lol:
PostPosted: Fri Oct 28, 2011 6:04 pm
:arrow:
