 Post subject: documentation
PostPosted: Sat Oct 08, 2011 9:13 am
I am still and somewhat amazed that there isn't any documentation that explains in detail what, how and is the better.
I have noticed that much has gone into radio BUT ST is used elsewhere as well.
It is often trial and error that yield a setting which is functional YET there is no way of knowing is it the better or is it optimized for your system
Ever since the v3 of ST I've used it with SAMBC but have switched to SAM DJ.
It works very well as I have the OS and SAMDJ in 64-bit YET there is no way or manner to test is what you have correct/optimized for your system.
It would be great for a tool that will tell you what needs to be done changed for the better and thereby set ST accordingly.
ST yields a great performance with the CPU running between 7-11% which is certainly its biggest improvement over the years
I use SAMDJ(ᵝ127) when programming(need music to program :D ) as well as in music forums having given up on internet radio due to licensing issues.
mapleleaf
win7-64
ASUS P8P67 deluxe
i7-2600K (OC 3.82)
24GB corsair
creative titanium HD
web site: http://www.mirana.net
 Post subject: Re: documentation
PostPosted: Sat Oct 08, 2011 11:29 am
Hi Mapleleaf,
I'm quitting my job and starting to work full-time on Stereo Tool. I really want to take things to the next level, and one of the things that are needed for that is a good description of what everything does. Preferably already in the program itself, but at least in a manual.
I'll be at my current job until the end of the year, after that I should have lots of time....
PostPosted: Thu Oct 20, 2011 12:05 am
Hi Mapleleaf,
Hey this is great news! I'll have to buy another license to support you when you do! Thanks for your hard work on stereotool.
