PostPosted: Thu Sep 15, 2011 2:01 am
Hi guys,
I've been using Stereo Tool for a while now (great btw) but a while back the 'Vamprecords Deep & Low' setting was removed as it was 'no longer necessary' or something. My problem is, I really loved it (much more than any of the other settings). It worked really well with my setup, I love those low frequencies growling at me.
Can someone point me towards a similar preset for the latest versions? Or at least give me an idea of how I might recreate it? It would be much appreciated :)
For the record, I have it saved as a configuration file for importing into the latest version, but I get the feeling something just isn't quite the same.
Thanks!
PostPosted: Thu Sep 15, 2011 2:07 am
Well it's possible that preset for erlier versions will not work same for new Stereo Tool versions. So you need to wait creator of preset to make changes, or you can just try to do edit it yourself.
